Baja 252
Old 09-22-2011 | 08:19 PM
Default Baja 252
Can you tell me the crusing range on a 98 Baja 252?
N2theDeep is offline
Old 09-22-2011 | 08:34 PM
JasonSmith's Avatar
3000-3500 rpm is probably in the 40-45mph range.
JasonSmith is offline
Old 09-23-2011 | 01:07 AM
Cruising speed or distance you can go on a full tank????
Griff is offline
Old 09-23-2011 | 08:01 AM
Dave M's Avatar
Veteran: Navy
At that RPM w/454 you are probably burning 12-15 GPH.
Dave M is offline
Old 09-23-2011 | 08:12 AM
When determining the distance you can travel on a tank of gas, always use 90 percent of the boat's total fuel capacity to give yourself a cushion.
E Colby is offline
Old 09-23-2011 | 08:18 AM
About a month ago we did a river trip on the Tennessee river from Lake Guntersville Alabama to Chattanooga and back. Conditions were calm. The boat is a 2001 252 Islander with a 350 hour 496 Mag (not HO) in it. Bravo 1 drive with a B1 24p prop. Attached is a picture of the gps readout for the trip. We burned almost exactly 60 gallons over 177 miles for an average of about 3 mpg. Typical cruise speeds were 30-32 mph. The moving average shown is lower since we had to idle and lock through and float some. I was really impressed with the boat on this trip. Try one, you'll like it!
Dan
BajaDan is offline
