Cleaning Out The Garage....take A Look Bbc Parts
WINTER IS COMING AND I WOULD LIKE FIND SOME SPACE IN THE GARAGE.....HERE IS A LIST OF WHAT I HAVE....
454 MKIV PARTS
.30 OVER 4 BOLT BLOCK...FRESH BORE AND LINE HONE 15HRS
HAIR LINE CRACK #4 CYLINDER....NEEDS SLEEVE...125.00
FULLY BALANCED ROTATING ASSEMBLY...FORGED CRANK (UNCUT) , SCAT I BEAM FULL FLOATING RODS, SEALED POWER FORGED PISTONS (NEED TO REPLACE ONE)...550.00
GRUMPY JENKINS 320CC INTAKE RECTANGLE PORT HEADS ALL STAINLESS VALVES 119CC CHAMBERS...DROPPED VALVE ON #4 EXHUAST...VERY REPAIRABLE.. NEEDS TWO VALVES AND CHAMBER CLEANED UP...NO CRACKS...425.00
LONGER COMPCAMS PUSHRODS FOR USE WITH THE JENKINS HEADS...HEAVY DUTY...95.00
WORLD PRODUCTS SINGLE PLANE INTAKE RECTANGLE PORT SQUARE BORE...LIKE NEW...FRESH WATER ONLY...175.00
HOLLEY 850 CFM MARINE CARB DOUBLE PUMPER FACTORY SPECS JUST REBUILT 15HRS WITH FUEL LINE AND PRESURE GAUGE...NO CHOKE...300.00
FINNED ALUMINUM VALVE COVERS POLISHED...75.00
FLYWHEEL, BELLHOUSING, WATERPUMP...NEW
OIL PAN, TIMING COVER...ECT
GEN 5 454 MAG MOTOR....1994
OIL PUMP PICKUP CAME OFF AND SPUN FRONT MAIN BEARING. NEVER APART STOCK BORES 195 HRS...
RECTANGLE HEADS, HIGH RISE INTAKE...ALL FACTORY
POWER STEERING PUMP, ALL BRACKETS, HOSES, WIRE HARNESSES.....EVERYTHING...
WHAT DO YOU NEED....???????????
TONS I HAVENT LISTED
E MAIL IS BEST
[email protected]
THANKS
454 MKIV PARTS
E MAIL IS BEST
[email protected]
THANKS
Shipping zip 60051 IL
ROTATING ASSEMBLY IS STOCK UNCUT CRANK
SCAT FULL FLOATING RODS I BEAM FORGED
AND PISTONS ARE FORGED SPEED PRO .30 over
Stock mercruiser balance I have the flywheel and
Balancer
Balancer
