6.2 IAC Motor
Found some, pass along the info, these fit 01 to 03 Ford Windstar with 3.8 v6. Get two for the price of one from mercury.
Duralast from Autozone #TV278
Standard # AC423
Motorcraft # CX1766
BWD # 50558 Oreilly carries
Standard # AC423
Motorcraft # CX1766
Be sure to compare them carefully. I bought a ford iac, and found the connector was different and it was turned 180*. No way it could be used even with the right connector. I have 496 Mag HO's.
[img][/img]
[img][/img]
I did, have it installed already. Pictures of it in link.
http://www.autozone.com/autozone/cat...2/TV278/image/
I havent had good luck grossing Merc part numbers but I have had some success with crossing Quick Sliver or Sierra part numbers. I usually start with Google and find the Merc number and work backwards towards NAPA. This holds true for many of the bolt on parts. Good luck.
