Mercruiser fuel pump problems...need advice... >
Old 10-02-2011 | 08:45 PM
randymbtech's Avatar
Question Mercruiser fuel pump problems...need advice...
Hey guys, having a problem with my Mercruiser 330 horse 454 in my '88 241 Liberator. I installed a brand new Mercruiser big block fuel pump over the winter when I re-built the motor. It ran fine for a couple months and then started flooding over after idling for a minute or two. I re-built the carb 3 times, until I did a fuel pressure test and found the mechanical pump putting out 12 psi at idle!!! This was too much pressure for the Q-jet, and was causing it to flood over. I replaced the pump with another brand new Merc pump, and now it idles perfect, BUT the boat won't hit high RPM! It bucks like hell and is running out of fuel over 4000 RPM. I did another test and found only 3-4 psi from this pump...AGGGHHH!!!
My question is, is there a better mechanical pump that i can buy that will actually put out the 6-7 psi that I need??? Thanks!
randymbtech is offline
Old 10-02-2011 | 08:56 PM
Once having those motors in my boat, I am familar with those mechanical fuel pumps on the raw water pump. Suggest you upgrade to these:
http://www.keitheickert.com/p-12460-...6-engines.aspx
Don't forget to clean out the lube bath and refill with the correct lubrication.
ROTAX454 is offline
Old 10-02-2011 | 09:06 PM
My fuel pump bolts to the block, not to the raw water pump housing, but thanks for the link! Mine is a big block Alpha, and has the raw water pump in the drive, should have stated that!
Old 10-02-2011 | 09:13 PM
Thats a great site, thanks for the link. Thinking about purchasing this one:
http://www.keitheickert.com/p-14089-...-chevy-v8.aspx
Old 10-02-2011 | 09:24 PM
That's the one you want. You can also get those from Jeg's or Summit. Probably a little cheaper.
picklenjim is offline
Old 10-02-2011 | 09:43 PM
That pump is cheaper than the Mercruiser ones I bought! I hope it's made better, these new Merc pumps are junk. I wonder why the pressures are all over the place? My boss had the same problem with his new Merc pump, to much pressure, and flooding his carb over.
Old 10-02-2011 | 09:45 PM
I just put on a Jeg's fuel pump mine runs perfect
firehawkcat is offline
Old 10-02-2011 | 09:50 PM
Which one?
Old 10-04-2011 | 09:31 PM
Cant remember the model # boats engines require alot more fuel delivery than a car Here it is Jegs brand model# 555-15961 110gph bbc they have a 80 gph but i went with more fuel delivery running around 450hp with edelbrock 750 carb
Old 10-04-2011 | 09:33 PM
Oh yea $ 54.99 could not find a fuel pump with this gph at any store in town thats why i went to Jegs
