Oil pressure sending unit problems... >
Old 10-02-2011 | 09:49 PM
randymbtech's Avatar
Default Oil pressure sending unit problems...
Hey guys, wanted to give a heads up about a problem I just had with my Mercruiser big block. Just built my motor over last winter. Installed a brand new Sierra oil pressure sending unit (bell style). Motor never had great oil pressure from day one. 45 psi cold, 25 psi hot. I wasn't happy, thought a new motor should be better. Used it all season, until last week, pressure started diving off under throttle...took a few years off of my life. I hooked up a mechanical gauge, and it had 60 psi cold, and 45 psi hot!!! Installed a new Merc seding unit...BAM...60 psi. It's getting hard to work with these junk new parts, it can make you crazy!!! Hope this helps somebody.
randymbtech is offline
Old 10-02-2011 | 10:21 PM
Does not surprise me, Sierra stuff is mostly junk.
Griff is offline
Old 10-03-2011 | 06:30 AM
Learned that the hard way!!! lol.
Old 10-03-2011 | 09:59 AM
c_deezy's Avatar
Don't use their exhaust manifold gaskets either. Coooked a set out in less than a season.
c_deezy is offline
Old 10-04-2011 | 05:54 AM
sending unit must also be compatable with gauge as well..not all will work together..
ezstriper is offline
Old 10-04-2011 | 06:21 PM
blue thunder's Avatar
Using thread sealant on an electric sender can cause this problem too.
blue thunder is offline
Old 10-04-2011 | 06:24 PM
Yah, I'm just glad the motor is healthy!
Old 10-04-2011 | 06:56 PM
how do you guys check a mechanical gauge while your up on plane? I've been wanting to try this as well.
jbraun2828 is offline
Old 10-04-2011 | 07:02 PM
Buy a proper length of copper tubing and wire tie the gage so you can see it at WOT.
Old 10-04-2011 | 11:10 PM
c_deezy's Avatar
Or you can just put a mechanical gauge in the dash. One of the fitting companies has a nice cloth braided hose, -4 is the smallest it comes in I think. Or you could have your local Parker store make you up one.
c_deezy is offline
