pluming a sea strainer >
Old 10-02-2011 | 10:06 PM
Default pluming a sea strainer
Hey guys can I run two water sources too the strainer? (Drive & bottom hull pick up) I know there is a fitting on the strainer for it. Know way if the out drive has more psi it would push water out the bottom of the boat and not to the pump/motor is there? Looking for more water and psi. I have a dump coming out of strainer to so if needed could bleed some off.
Thank u
skydog is offline
Old 10-03-2011 | 05:01 PM
My 251 checkmate had 2, with a valve to select between, one in the hull the other a hose connection on the transom..pretty slick...don't know about the diff in pressure though..
ezstriper is offline
Old 10-03-2011 | 07:51 PM
Done will let you guys know how it works! This 1100Hp monster needs water!!!! Hahahahah
skydog is offline
