Trim gauge reading wrong
Old 10-03-2011 | 02:34 PM
Default Trim gauge reading wrong
Hey everyone,
I noticed my Alpha One wasn't moving properly and so I checked the fluid, sure enough it was fairly low. I filled it back up and it worked like a charm.
But now whenever I use the trim, the gauge is inaccurate. It bounces a lot and never goes fully "down" despite being down. But it does move along with the drive, just as if its calibrated to being higher on the gauge reading.
Any thoughts?
Thanks!
Captain YARRR is offline
Old 10-03-2011 | 02:36 PM
You can adjust it by turning the little puck shaped senders on the sides of the drive.
Griff is offline
Old 10-03-2011 | 03:14 PM
Too Stroked's Avatar
x2. The starboard side is for the position of the trim gauge. The port side is for trim limit.
Too Stroked is offline
Old 10-03-2011 | 03:49 PM
Perfect. Thanks guys!
Old 10-03-2011 | 05:03 PM
sounds like the sender is getting ready to fly south....
ezstriper is offline
Old 10-04-2011 | 12:26 AM
I am guessing I'll need an adjustable wrench or something to turn that sender?
Old 10-04-2011 | 05:52 AM
should only need a phillips screwdriver to adjust
