1990 Aronow 37
Old 10-04-2011 | 03:15 PM
Default 1990 Aronow 37
if I had enough storage to keep it I would but it's gotta go.
Boat is rock solid, all fiberglass inner liner, including cuddy. Speaking of the cuddy, it is large for a boat this size, Top Guns or fountains aren't even close. That's the main reason I wanted it.
Needs engines, trans, drives. The interior is all there (except for rear bench, I have the base for it) but completely mildewed. Good news is that the cuddy liner is perfect, just get new cushions and that's that. cockpit floor is dry, but stained and so the original loncoin will need to be replaced with something else.
Has AC (no generator) toilet. The Dash and gauges, controls in good condition and complete (minus hydraulic helm), transom assemblies only have a couple hours on them. All shift cables, throttle cables, wiring, engine plug ins, motor mounts (except one is missing, not sure where that went) everything's there.
The top deck will need to be wet-sanded, and may need to be clear-coated, but not sure. The sides are nearly perfect, only blemishes are on both sides where the swim-platform was molded on, and you can see where they blended it.
No trailer
$6,500
send email for more [email protected]
Attached Thumbnails 1990 Aronow 37-clark-20111002-00569.jpg   1990 Aronow 37-clark-20111002-00567.jpg   1990 Aronow 37-clark-20111002-00559.jpg
schmiddy is offline
Old 01-14-2023 | 12:40 PM
good afternoon by any chance is this aronow still for sale and do you know where thank you paul 631 786 2536
signature is offline
Old 01-14-2023 | 01:40 PM
F-2 Speedy's Avatar
old thread but he was on here a couple days a go,
F-2 Speedy is offline
Old 01-20-2023 | 01:19 PM
that is the boat from Chicago back in the early 90's , we worked on it for a guy named FAT JACK the asphalt rat., boat was in the Miami boat show , had omc king cobra packages . was repowered with 468 bbc blower engines, and trs drives , fat jack couldn't figure out how to drive the boat in lake Michigan at all, it was the joke around the shop
throttleman is offline
