AN water inlets vs. crossover >
Old 10-07-2011 | 12:05 PM
Default AN water inlets vs. crossover
I see some guys using little plates that have AN style fittings, that feed water to each side of the block, instead of a crossover. I like the look. Also, with my crossovers, with the 1 1/4 hose feeding them, makes for it hard to read the timing marks on the balancers.
Guys running this setup, how are you plumbing your system?
MILD THUNDER is offline
Old 10-07-2011 | 12:14 PM
I like that setup too, but the only times I have seen it used is when they are cooling the exhaust first, which heats the water and eliminates the need for a thermostat
302Sport is offline
Old 10-08-2011 | 10:46 PM
The other way I have seen them used is when using a cam driven water pump. That pump has one inlet and 2 outlets, so it is easier to use the individual plates with the AN fittings.
Eddie
Young Performance is offline
