Need a BBC distributor >
Old 10-10-2011 | 07:36 PM
donzi matt's Avatar
Default Need a BBC distributor
Looking for a distributor for a BBC, specifically my 87 420 HP. Needs to have the screw in studs on the distributor. Don't know why, but mine has eaten two sensors out of the distributor, so I think it is time to just change the whole darn thing. Thanks in advance.
donzi matt is offline
Old 10-10-2011 | 07:48 PM
Does the shaft wobble inside the housing??
I have some back home but it will be end of Nov before I get back that way. Look me up then if you havnt found one by then.
Jeff
jeff1000man is offline
Old 10-10-2011 | 08:04 PM
donzi matt's Avatar
No, the shaft feels nice and tight. Doesn't really make sense but I don't like riding on one motor.
Old 10-12-2011 | 04:37 PM
Have a merc in great shape w/wires for 200.00 252 422 8854
screammachine is offline
Old 10-12-2011 | 04:55 PM
I went with these on this set of engines as an experiment just for the cost and to see how well they worked.
Took a few tries to get the curve and the amount of advance right do to the design, but now that they are set up, they have been working great through 27 hours on each engine.
They use a cheap 3 prong plug that we changed to standard automotive bullet connectors since the ones that came on it will wiggle loose.
They will wire right in though. and it takes a lot of the wiring clutter off of the engine.
http://www.jegs.com/i/Mallory/650/YLU624AV/10002/-1?parentProductId=748619
Old 10-12-2011 | 05:36 PM
Rookie's Avatar
Is this the style you are looking for? $50+ship
sorry for the small pic
Rookie is offline
Old 10-19-2011 | 04:44 PM
Ive got one out of a 420
Needs one of the threaded terminal posts replaced, otherwise good working order.
$50+ ship or dist & t bolt 4 coil to your door for $100
If interested pm me
Mike
scarab63 is offline
