Go Back  Offshoreonly.com > Boat Club Forums > Grand Lake/LOTO/E-Dock
Surveyor in Tulsa, OK? >
Old 10-11-2011 | 08:50 AM
Default Surveyor in Tulsa, OK?
Any of you guys know a surveyor in the Tulsa, OK area? For the most part, I just need someone to put their eyes on the boat, check for moisture and electronics as I'm buying without power. Thanks for any suggestions you can send my way!
TCBoss302 is offline
Old 10-11-2011 | 05:05 PM
You might try calling Ughly Johns at grand lake. I used a surveyor about 5 years ago that did alot of there marine surveys. Be prepared to spend a little coin. If I remember correctly he charged me $12 per foot plus about $5 per mile if he has to drive to view the boat.
powercat is offline
Old 10-11-2011 | 07:44 PM
Found a certified surveyor online, thanks.
Old 10-13-2011 | 10:12 PM
carter38's Avatar
Ben Harman used to do them in the tulsa area.
carter38 is offline
Old 10-14-2011 | 07:48 AM
Carter,
I talked to Ben but he was so busy, he couldn't get to it for at least 2 weeks. The boat also ended up going to Joplin, so I found someone close to there, survey will be done on Tuesday. Thanks for the suggestion!
Old 10-16-2011 | 07:58 PM
mroberts's Avatar
Originally Posted by TCBoss302
Carter,
TC -
You might mention which boat it is you are looking at.
Chances are that if the boat was in this area, plenty of us on here know about it and could tell you plenty.
mroberts is offline
Old 10-16-2011 | 10:41 PM
Originally Posted by mroberts
TC -
Matt you are right that we might know the boat. It is LV's Outerlimits. The below thread is how I know. The question is what is Larry going to replace it with.
http://www.offshoreonly.com/forums/g...a-ok-area.html
E Dock DD is offline
Old 10-17-2011 | 07:41 AM
Quinlan's Avatar
http://www.offshoreonly.com/forums/g...a-ok-area.html[/QUOTE]
Here Kitty Kitty Kitty! lol
Quinlan is offline
Old 10-17-2011 | 07:43 AM
Correct, it's Larry's 37, does it look as good in person as it does in the pics? The thing looks brand new!
Old 10-17-2011 | 10:16 AM
WARPARTY36's Avatar
Drive to arrive alive!!!
Yes the boat looked brand new in person the last time I was around it.
WARPARTY36 is offline
