bravo 1 gear ratio?
Old 10-11-2011 | 04:03 PM
Default bravo 1 gear ratio?
How can you tell the gear ratio in a bravo 1?
chaselee is offline
Old 10-11-2011 | 04:05 PM
It is usually stamped in the decal on the side of the drive. Also, if the gear set is out, you can count the teeth on the upper/lower and pinion and then match it up I think
hawaiianhopper is offline
Old 10-11-2011 | 04:09 PM
Its stamped underneath the MerCruiser sticker, on the port side of the upper housing. Stamped into the aluminum. It can also simply be printed on the sticker in the same location. Hope this helps.
CanDo is offline
Old 10-12-2011 | 01:06 AM
Probably 99% of merc black engine boats had 1.5 ratio drives.
Griff is offline
