engine flusher >
engine flusher
engine flusher
Old 10-16-2011 | 07:09 AM
classclown's Avatar
Registered User
Default engine flusher
Hey I'm looking for a engine flusher that would work with my outdrive but the water pick ups are at the front of the nose cone. (high performance bravo one) The round or square design do not make a complete seal or stay on.
classclown is offline
Old 10-16-2011 | 08:44 AM
Macklin's Avatar
Assuming you have dual water pick up Bravo since you said the regular flush muffs won't stay on. I had a Bravo outdrive that only had the front water pick up. (Correct me if I am wrong, but they only made those for one year - 2000.) That required a special flush muff that Merc charged an arm and a leg for.
But, never had a problem flushing my Bravos that had dual water pick ups. It will shoot water out the front pick up when you turn the hose on, but as soon as you fire up the engine the water pump will take it up.
Try a better set of muffs.
Macklin is offline
Old 10-16-2011 | 11:05 AM
http://www.jrmarine.com/products/bmax-parts.htm like this
TWIN-SPINS is offline
Old 10-16-2011 | 11:10 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
It sounds like you need to put a T in the water inlet hose between the transom assembly and the SWP.
Sydwayz is offline
