Input on 33 outlaw >
Input on 33 outlaw
Input on 33 outlaw
Old 10-16-2011 | 10:17 PM
Default Input on 33 outlaw
Currently I have a 24 outlaw and kicking around the idea of picking up a 98 33 from a friend that needs motors. What is your guys input? Any problems with a 33 or anything to look for with it? What bahas had problems with the hulls?
blackta is offline
Old 10-16-2011 | 10:33 PM
Also what is a 98 33 worth
blackta is offline
Old 10-16-2011 | 10:38 PM
As with any boat you have rot and deterioration to deal with. Being a 98 it would depend on how it was taken care of. I'd look for blisters in the gelcoat. I'd have the hull surveyed for rot in stringers and transom. What seems like a good deal now might turn into a expensive repair later. The 33 was by most peoples opinion including myself one of the best hulls they put out. Lots of cockpit room and handles the rough stuff as well as the fact that its a faster than most hull. You'll most likely have a deeper X dimension than the 33's built after 2002 as Baja raised it, so you'll probably need to run 3 blades to get optimum performance. Good luck in whatever you do, but again make sure you check for rot in the wood.
Irishtornado is offline
Old 10-17-2011 | 07:28 AM
Depending on your budget, you could look for a newer boat. Many Baja's from the 90's have had moisture and rot issues.
A.O. Razor is offline
Old 10-17-2011 | 07:58 AM
I can get this one pretty cheap supposably just needs power
blackta is offline
Old 10-17-2011 | 08:05 AM
Love the boat. If you can pick it up for 10k or less then it's a good deal. The boat complete in great condition would prob only sell for 50k. A used boat ALWAYS needs more then you think. Sure the drives are tired also.
offshorexcursion is offline
