Shifter linkage change for LH prop >
Old 10-17-2011 | 07:52 AM
Dave M's Avatar
Veteran: Navy
Default Shifter linkage change for LH prop
When you change your shifter to run a left hand prop, is there additional adjustment to be done? Or, do you just attach the cable to the other side of the lever and roll? BTW, I have Merc zero effort controls.
Dave M is offline
Old 10-17-2011 | 08:10 AM
"just attach the cable to the other side of the lever and roll?"
That's all I had to do. Getting it hooked the first time was a little tricky, but it gets easier with every change.
Thunderstruck27 is offline
Old 10-17-2011 | 09:03 AM
Sydwayz's Avatar
Forum Regulator
Just switch it at the lower end of the shifter Dave.
However, there is a special Mercury calibration tool for fine tuning the shift linkage on top of the motor. You probably don't have any reason to need this though.
Sydwayz is offline
