Go Back  Offshoreonly.com > Owners Forum > Hustler
How fast?  31 Hustler w/ pair 300 Pro Max >
Old 10-23-2011 | 11:26 PM
Default How fast? 31 Hustler w/ pair 300 Pro Max
How fast is a 31' Hustler straight bottom V with a pair of 300 hp Mercury Pro Max outboards The motors are turning 23 " pitch 3 blade Mirage props. It's also bottom painted. I am guessing 65 to 70 mph. Thanks.
bunky1957 is offline
Old 10-24-2011 | 03:18 AM
There's no 31 Hustler. You mean 32?
frogger1403 is offline
Old 10-24-2011 | 08:17 AM
I'd guess similar. If the motors are Pro Max's and not 300X's you'll be down about 70 hp's (total) and I'd guess maybe mid/high 60's w/those.
If current set up can turn those wheels 6000 RPM (assuming 1.62 gears which most 300's have) you'd be at 72.6 @ 10% slip.
The X's are monsters!
Twin O/B Sonic is offline
Old 10-24-2011 | 10:52 AM
Default 31 hustler
Maybe it is a 32' , there were no identifying numbers, but it was about the same length as my 311 Formula
Old 10-24-2011 | 12:35 PM
bor's Avatar
bor
It's a 32 I have one also but whit diesels 320 hp each and see 72 mph on the gps.
but I had a friend whit a 31 scarab Viper and that was at least 1 ft longer then my hustler 32 !
bor is offline
