Looking to upgrade air compressor >
Old 10-30-2011 | 07:09 PM
Default Looking to upgrade air compressor
I'm looking at upgrading my current useless compressor to one that will let me sand, buff, and spray without having to wait for it to recharge. What size tank, HP motor, and CFMs would be needed?
Looking to spend $600-800 for a used one. This caught my eye, but not sure, I really don't know much about them.
http://dallas.craigslist.org/ftw/tls/2670993220.html
thanx
bert4332 is offline
Old 10-30-2011 | 08:19 PM
C_Spray's Avatar
Diamond Member #001
The single biggest factor is usable CFM at 90 psi or better. Check the airtools that you intend to use, and see what their requirements are.
C_Spray is offline
Old 10-30-2011 | 08:50 PM
Default fixx
the one you looking wont do the job jor you,,i would up your price and look for a bigger one..18 cfm and up to run your air buffer..
http://www.searchtempest.com/results...min&maxAsk=max
Oct 29 - 5 hp air compressor Ingersoll rand - $1300 (fort worth ) general pic
FIXX is offline
Old 10-31-2011 | 05:45 AM
And what number of CFM falls into the range of sanding buffing?
bert4332 is offline
Old 10-31-2011 | 07:07 AM
try to find a used Quincy 5 hp, a twenty yr old maintained quincy will outlast any of the big box name brands by decades...
i picked one up last year for $100 been running ever since.
delsol is offline
Old 10-31-2011 | 07:32 AM
look for a rotary compressor, they last forever and put out a ton more cfm than a recip.
a 5 hp should be more than enough
You will need a tank probably, just use your old compressors tank.
yahoo is offline
Old 10-31-2011 | 09:43 AM
C_Spray's Avatar
Diamond Member #001
If it's not marked on the tool, check the owners manual or the manufacturer's web site; there can be a very wide variation.
C_Spray is offline
