454 engines 1 complete 1 short 3 bare Imco Manifolds >
Old 11-01-2011 | 07:51 PM
Sick Stinger's Avatar
Brotherhood #1
Default 454 engines 1 complete 1 short 3 bare Imco Manifolds
i have a few 454's at the shop
1- Comeplete from top to bottom. Has all acc. on it with harness. Hour meter read 55 on it also per last onwer said it had 55 hours on motor. GM perf. aluminum intake uni lite dist. holley 600 carb (new) roller rockers, was told mild cam, has 1 piece push rods. Four bolt main block mini high torque starter. Has Cross over and water outlet housing
1500 less Imco's
2500 With imco's
1- 454 0.060 over 9.8/1 has 150 hours on motor. Small cam non roller 4 bolt main has base pan timing cover cam and lifters
500
3- 3 bare 454 blocks that are in need of going to machine shop. They have caps
100 each
I have 2 sets of the Imco Manifolds and Imco Risers. They are a wet system
Sick Stinger is offline
Old 11-01-2011 | 09:41 PM
What crank and rods are in 454 short block ?
rivermonkey is offline
Old 11-01-2011 | 09:47 PM
Brotherhood #1
I would say cast but not 100% i can teat it down if you really need me to
Old 11-02-2011 | 06:28 AM
How much for the Imco manifolds?
1BIGJIM is offline
Old 11-02-2011 | 06:45 AM
Brotherhood #1
1300 for a set
2000 for both sets
Old 11-08-2011 | 07:58 PM
Brotherhood #1
1 set of Mani's 1300 Shipped or 1200 you pick up shipping.
I can complete the short block with stock 330 heads intake and carb if needed for another 250 free stock rockers or 125 for crane's with 1 piece push rods
-Mike
