CMI header removal >
CMI header removal
CMI header removal
Old 11-02-2011 | 01:33 PM
onesickpantera's Avatar
Default CMI header removal
Looks like cylinders 1 and 8 have a bolt that is VERY tight to the header. I'm sure if I swear enough and hold my tongue just right I will get it sooner or later(vice grips may break it loose but not a lot of room there). I figured before I bloody my knuckles I would see if anyone had any tricks/pointers for removing this bolt.
Thanks!
onesickpantera is offline
Old 11-02-2011 | 01:52 PM
Forgot to mention they're 5/16" allen head bolts. I'm thinking a modified/shortened allen wrench may get in there.
Old 11-02-2011 | 02:01 PM
Have you tried a ball end allen from the bottom? it should fit
mr3dman is offline
Old 11-02-2011 | 02:05 PM
Default Allen bolts on cmi
5/16th allen wobble head, I use a 4'' with an electric impact. Zips them right out.
voodoo too is offline
Old 11-02-2011 | 02:25 PM
Going to borrow a ball-end after work. It might work but man it is tight!
If not a modded allen wrench cut on the shorter end might mork.
Thanks for the suggestions.
Old 11-02-2011 | 11:02 PM
Ball end with a box end wrench on the other end broke it loose. These things are way lighter than I though they would be!
Old 11-03-2011 | 08:34 AM
Glad it wasn't a problem for ya!
mr3dman is offline
Old 11-04-2011 | 01:26 AM
I used ARP stainless studs on my CMI's and really liked them compared to using bolts.
Griff is offline
Old 11-04-2011 | 10:04 AM
I have studs on my Stellings, but only on the 4 bolts where the tube sweeps in the opposite direction. Tight side has allen bolts. Would love to be able to do them all on studs. But at least having the other ones on studs makes life easier installing and removing.
MILD THUNDER is offline
Old 11-04-2011 | 01:37 PM
Default fixx
you would think all the money spent on thease marine headers the engineers would give you a little extra room arounf the tubes to make the job go easier..i usuallly take out the easy ones first and leave the ones in the fromt and back in with a few threads in the head,then work the tight ones and the header will move with the bolt as its be removed..
FIXX is offline
