Autometer gps will this Garmin OEM GPS 17x HVS Sensor NMEA 0183  work? >
Old 11-06-2011 | 02:21 PM
Default Autometer gps will this Garmin OEM GPS 17x HVS Sensor NMEA 0183 work?
I have the Garmin OEM GPS 17x HVS Sensor NMEA 0183
And it will not work with my autometer gps speedo the manual is wrong with the wire codes it states to use the gray and white are writen the same codes do i use gray or white is my speedo broke it will not do anything .
http://static.garmincdn.com/pumac/24...tilingual_.pdf
Rockfish71 is offline
