Guys in FL - How often have you had to replace your impeller...
Unless you make really good friends with the bottom, you shouldn't need to change your impellor any more frequently than anywhere else.
It's good practice to change it once a year or every 100 hours, however, simply because it is a wear item.
Now, if you fill your motor with sand frequently, that's another story.
BD is right on! Salt water has nothing to do with it. If you are NOT tilling the bottom, which happens alot in Fl. with all the shallow water, then the impeller should last a long time. This is in reference to the raw water pump on M/C big blocks.
Hope this helps,
MD
Hope this helps,
MD
I say once or twice a year... just preventative maintenance ya know... Better safe than sorry!
(What you see, is what you get!)
"Live every day to it's fullest for you give a day of your life to it."
Use Globe Rubber Works "Blue" Impellers. They last much longer the the standard black-rubber impellers and they don't cost that much more. BoatFix.com sells them at a discount.
Mercruiser belt-drive pumps to present take Globe p/n 2000
and all Alpha, R, #1 outdrives, and 80hp and up merc outboards take Globe p/n 1000.
razor1115
4
03-25-2004 11:13 PM
