1999 K1500 Suburban towing capacity >
Old 11-17-2011 | 09:06 PM
Default 1999 K1500 Suburban towing capacity
Does anybody know what the towing capacity would be on a 1999 k1500 suburban with 350 engine and 373 gear ? I don't have the manual and the sticker on the drivers door is missing. I have been told 6000 lbs. I think that is to low. My 2002 trailblazer can pull 5600 lbs.
moon i is offline
Old 11-17-2011 | 09:28 PM
http://www.offshoreonly.com/forums/t...er-thread.html
prostock85 is offline
Old 11-17-2011 | 09:30 PM
looks like 6500
Old 11-17-2011 | 10:12 PM
tcelano's Avatar
I had a 97 Tahoe with the same transmission as is in your truck. I made two trips towing a box trailer that was probably 8,000. Smoked a transmission not long after each one....
tcelano is offline
Old 11-18-2011 | 12:47 AM
http://www.offshoreonly.com/forums/g...ly-photos.html
Take a look in the above thread. I would not tow more than 6500lbs with a burb. It just does not have the abillity to do so safe. And if possible, run a good elec over hyd. brake setup on the trailer.
A.O. Razor is offline
Old 11-18-2011 | 11:14 AM
Thanks for the info. I will be pulling a 25' sunsation that has a total weight of 5500 lbs with trailer and a full tank of gas.
moon i is offline
Old 11-18-2011 | 11:23 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
The problem with a Suburban, is that we never tow with the TRUCK empty. You then have to worry about the COMBINED weigh rating. Tow/weight ratings are calculated with an enpty truck, and no cargo.
2 adults, 2 kids, luggage, dog, coolers, etc etc. You will max out that Sub even towing 5500#. Also, don't believe anything you read on what your rig weighs unless you are reading a scale ticket at a truckstop.
IF, you are going to tow with this setup, I HIGHLY recommend Firestone or AirLift aftermarket air springs, as the factory coil springs suck for towing stability.
Sydwayz is offline
Old 11-18-2011 | 01:37 PM
youll be fine with that boat.
soldier4402 is offline
Old 11-18-2011 | 01:39 PM
Curb Weight - 4820
CVWR - 7700
Payload - 1980
Max Trailer - 6500
Suburban 2500 2WD:
Curb Weight - 5286
CVWR - 8600
Payload - 3314
Max Trailer - 10000
Old 11-18-2011 | 03:18 PM
Default fixx
correction,,front are tortion and the rear are leaf springs..if he adds one leaf it will be good for 1500 lbs of weight..
FIXX is offline
