97 502 MPI Won't Start
I would also check the dist cap & rotor if corroded it may not be getting enough fire to the plugs, Also I have seen that an injected engine that gets flooded can contaminate the oil by washing the cylinders. 1 more trick I learned pop the coil wire loose but not off & try it. Was told the increased gap will make a hotter spark at the plug & should give an idea where to go from there.
