Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Removing Painted on Graphics >
Old 11-21-2011 | 03:26 PM
Default Removing Painted on Graphics
I have a 93 Fountian 27 that has the brown & gold painted on graphics. We are planing on a new int & new graphics. I'm planig on trying to sand the old ones off and sand and buff the hole boat, has anyone tryed this with any success ? Thanks
BS_27 is offline
Old 11-23-2011 | 01:11 AM
glassdave's Avatar
Neno the mind boggler
its kind of a crap shoot to do that. If you do decide to give it a go you have maybe a 50/50 shot at any success so be prepared to paint if necassary. Many times the gel under the graphics will fade at a different rate then open gel.
08 OPA High Points Champion
glassdave is offline
Old 11-23-2011 | 10:54 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
A buddy sanded his off. If you look close you can still see the old outline. His new graphics covered most of the old, so only noticeable where there was no overlap.
US1 Fountain is offline
Old 11-23-2011 | 10:55 AM
I'm going to give it try the fading is my concern. was wondering how much sanding can the white gelcoat take before going through, and I am preparid to paint if I have to. any input on vinyl graphics or should I have them painted on ?
BS_27 is offline
Old 11-27-2011 | 12:52 PM
I did some research and found that "easy off heavy duty" (oven cleaner yellow can) would taek off paint and not mess up the gel coat. I bought it and removed an old painted name on my boat and it worked like a charm. I used a plastic scraper as well and it came up super easy and looks great!
Aequitas is offline
Old 11-28-2011 | 03:56 PM
that only works on hand brushed type paints(one shot)..if sprayed in imron or something simular sanding/painting or covering(wrap) about the only options that work well...
ezstriper is offline
Old 12-17-2011 | 12:56 PM
We gave it a try last week the graphics sanded of well and we used several different grits and a lot of buffing the jel under the graphics looks great but after hours of work the the unpainted jel was just to yellow, to much difference to use, so are local painter was happy to hear that, LOL and its off to the paint shop.
BS_27 is offline
Old 12-19-2011 | 10:47 PM
onesickpantera's Avatar
How did you protect the surrounding gel coat and any pointers for not sanding too deep? I've been thinking of this but also afraid the gel under the paint will be too white.
onesickpantera is offline
Old 12-21-2011 | 09:53 PM
To protect the surrounding areas I masked them with duck tape. The cheaper stuff works better because it comes back off the easiest .
Esal is offline
Old 12-27-2011 | 12:46 PM
bigboat28's Avatar
What grit paper do you use. Any pointers? I have stripes I want to change.
bigboat28 is offline
