Go Back  Offshoreonly.com > Owners Forum > Powerquest
1 inch spacer and trim tabs >
Old 11-26-2011 | 10:33 AM
Default 1 inch spacer and trim tabs
Thinking of changing some things on my 280 over the winter has anybody used a 1inch bravo spacer and had gd luck, what about longer trim tabs. Hope everybody had a great Thanksgiving
boatrider82 is offline
Old 11-26-2011 | 06:29 PM
Had a 1" spacer in my bravo when I got the boat. Still got it. I could be talked into selling it. I'm in Slidell,La.Bob
Bob280Silencer is offline
Old 11-27-2011 | 01:40 AM
Well pm a price on it then maybe while im there I can get a measurement on the hatch lift
Old 11-28-2011 | 10:44 AM
Josh LaFountain's Avatar
Mine has a spacer and it helps with stability at high speeds.
Josh LaFountain is offline
Old 11-28-2011 | 07:23 PM
i put in a 1" spacer to help with prop slip when getting on plane. big help.
specialk is offline
Old 11-28-2011 | 09:13 PM
my old 280 had a 1" spacer, previous owner installed it and said he picked up a couple mph, I bought 16" tabs from insta-tab and reused my rams and pump, I think it helped with the chine walking
Pete280 is offline
Old 11-29-2011 | 04:34 PM
Thats what I was thinking about doing calling insta trim and getting there longer tabs, just wanted to make sure they made an improvement before spending the money
Old 11-29-2011 | 04:37 PM
Sounds like a gd idea to put the 1 inch spacer on thanks everybody for there input!!
Old 11-30-2011 | 06:56 AM
I want to do the same upgrades over the winter. So does everyone agree on a 1" spacer? Over a 1/2" or 1-1/2"? I can even blow out a P5X comming on plane and am dire need for a spacer. I went to a 16" long tab and when wide open and it starts to chine walk over 70, the tabs are too high on the V to even quiet it down. I think I am going with 24" tabs, possibly horozontal? Lets nail this down. I think everyones 280 has the same high X dim.
AZ Lineman is offline
Old 11-30-2011 | 09:41 AM
Great thread!
Im looking at the same upgrades on my 280. I was going to get the longer tabs from insta-trim and add a 1" drive spacer. What prop and horsepower are you guys running? I have a stock 502 with a 24 Bravo. I was also going to try some different props.
murf is offline
