Dart Pro 1 w/Gen VI Valve cover fit?
One of the "Masters" on this Forum stated that a Gen VI Valve cover will NOT seal on the Dart Pro 1s using the Gen VI Valve cover o-ring.
I do not want to assemble the engine and end up with a leaking valve cover.
It looks to me like the o-ring makes contact all the way around the top of the head although in a couple of areas it is near the edge.
Has anyone tried the Pro 1s with the o-ring valve covers?
THANKS!
THANKS!
If you are using roller rockers its a mute point, and I am betting you are if you are using dart heads
I sold 2 sets of brand new Gen 6 covers because of that. Nice valve covers for a stock engine.
From Dart tech support
Gen VI valve covers with an o-ring seal WILL NOT seal on our Pro 1 cylinder heads.
Thank you,
Tony Hornak
Dart Machinery, LTD.
353 Oliver Drive
Troy, MI 48084
Phone: 1-248-362-1188 ext. 139
Thank you,
Tony Hornak
353 Oliver Drive
Troy, MI 48084
THANKS!
I got out the die-grinder
Early model gaskets for me.
HP500 cam, Energizer rockers, cast OE Gen VI covers. I had to grind off the rocker nuts but the rockers seem to clear.
I'll post if there are any issues.
Related topic- I have Dart Pro-1 heads and Eickert two-piece valve covers. The original setup would not clear the roller rockers, so they made a taller base section. That causes interference with E-top headers, so they had to get 1/4" exhaust flange spacers.
