750 hp baja 25 outlaw >
Old 12-12-2011 | 09:51 PM
Default 750 hp baja 25 outlaw
Whats up boyz i need some help iam having a 750 hp engine put in my 25 outlaw in spring, I need some info on what I should do with the drive setup. Do I put on shorty or ext box or both and if I should go full hydraulic steering with one ram or 2 thanks. O ya my drive now is bravo 1 with 300 tame hrs
soundwave is offline
Old 12-12-2011 | 10:35 PM
I'd recommend Extension Box, Dual Ram FULL hydraulic steering and a Imco SC Exreme drive you could skip the box, but your drive won't last that long and without full hydraulic steering neither will you. Not trying to be a ass just stating what I know to be facts. Your looking at speeds above 80mph.
Irishtornado is offline
Old 12-13-2011 | 06:39 AM
DUAL RAM full hydro steering is a must!
POWERPLAY J is offline
Old 12-13-2011 | 09:16 AM
When setting up your boat, do one thing at the time. Dual hydraulic steering is a must though. Don't think so much about the shorty and box, spend the money on making it live to begin with, You have a timebomb on your hands, so be prepared to spend money on new drive parts. Keep spare gears, shafts ect. if you want to avoid down time. Important but often overlooked things when doing this kind of swap are.
Full dual ram hydraulic steering.
Fuel system that can feed the power without problems.
Cooling system.
Drive. (Mr. Gadgets, Max Works ect.)
Don't add both the box and shorty at the same time. Do the box and make it work, then you can try a shorty. Doing several things at once when setting up, is just a nasty can of worms.
A.O. Razor is offline
Old 12-14-2011 | 02:42 PM
JasonSmith's Avatar
You can't have an extension box without hydraulic steering. It is not possible to use the factory steering with a box.
JasonSmith is offline
Old 12-14-2011 | 07:13 PM
articfriends's Avatar
Cooling system.
Really good advice, bump up the power THEN change drive height, setback etc otherwise if boat doesn't have the speed you are expecting you will be chasing your tail, Smitty
articfriends is offline
Old 12-30-2011 | 06:54 PM
Isnt that the truth.
Baja_man is offline
