Go Back  Offshoreonly.com > Owners Forum > Advantage
speed and handling of a 27 Victory >
Old 12-13-2011 | 02:35 PM
Default speed and handling of a 27 Victory
I was wondering if you guys could help on some questions.What kinds of speed could a person expect from a 27 Victory with 800 hp...how would it handle at high speeds and in general how do they ride? thanks
WR-1 is offline
Old 12-13-2011 | 04:04 PM
Default 27 victory
i have a 27 victory they ride great an handel speed well they drive great at 80 with no tabs..660hp will get u 80 an after that it dosent react to more power well..at 85 it like a wall that i couldn get past i have a 540ci that eddie young dyn at888hp it will get there fast but cant get past the wall...jus my experence
American Thunder is offline
Old 12-14-2011 | 07:57 AM
That's crazy how that works..at 228 more horses u probably were disipointed with only a 5mph gain..have you had the bottom of the hull looked at to see if that may be an issue?..Do you experience any chine walk at higher speeds?
WR-1 is offline
Old 12-14-2011 | 10:52 PM
Mine rides great and handles like a slot car, but at 575 hp it is rather slow at 63mph. It is possibly for sale though.
snapmorgan is offline
Old 12-16-2011 | 08:03 AM
I would have thought a 27 w/575 would be faster. Is the 27 a fairly heavy boat? I know my 32 is fat, but still gets close to 80 with twin 496s.
CrownHawg is offline
Old 12-16-2011 | 08:22 AM
I think the 27 has a little hook in the hull, I know the 30 does, this needs taken out to get better performance, the 32 doesnt have the hook.
the bear is offline
Old 12-17-2011 | 01:30 AM
Yes the 27 does have a little bit of hook in the hull and thats how they get them to ride nice with no tabs. Problem is the hook isn't very good for 80+mph. With 620hp originally in my boat, fastest I ever saw was 73 and handled great. With 800+ now, I've seen 86, but handling is very dependent on load. The more fuel the better (lower center of gravity). Overall the boat rides very nice, its nice to cruise at 60mph not even stressing anything.
The 32 is a newer design and also has a triple step hull whereas the 27 only has a single step. That helps the 32 go a little faster. Mind you the 27 was originally designed in 1991 when the biggest motor you could put in it was about 450hp...I don't think they evisioned us putting 800+hp in these
ToMorrow44 is offline
Old 12-12-2012 | 02:38 PM
Mine has a 454 mag with procharger 6 psi boost runs 72 to 75 with a 26p bravo 1
Plus Man is offline
Old 12-14-2012 | 12:04 PM
mine was a 454 carb, 53mph
trex232 is offline
Old 12-15-2012 | 09:47 PM
What is your X-dimension?
Advantage 575 is offline
