painting drives
Old 12-14-2011 | 09:11 PM
bcfountain's Avatar
Registered User
Default painting drives
thanking about painting my drives with a expoy base paint,something like petit.i boat mostly in fresh water,but some times in salt.what do you guys think?
bcfountain is offline
Old 12-14-2011 | 09:18 PM
I'm gonna try por 15 marine. Heard a lot of good things about it. I use their paint on all my car parts and it holds up very well
demag67 is offline
Old 12-14-2011 | 09:36 PM
The Merc Phantom Black rattle can is one of the best paints you can get. Let it dry really good and you will be impressed.
Keith Atlanta is offline
Old 12-15-2011 | 07:56 AM
I've had good luck with Dupont Nason, and PPG Concept over an epoxy primer. My gimbles and K planes have been done with either and have lasted several years.
THRILLSEEKER is offline
Old 12-15-2011 | 12:04 PM
bcfountain's Avatar
Registered User
i have used that paint before,its just black is such a boring color.i am thinking eletric blue.its the same color i painted the motors.looks like the blue that merc uses on the blue motors,just brighter.
Old 12-15-2011 | 02:20 PM
Rookie's Avatar
I did mine last winter/spring Etching primer and PPG single stage. Fully pitted TRS saltwater drives. Filled, primed and painted. A ton of work filling them and sanding. So far so good.
Attached Thumbnails painting drives-imag0302.jpg   painting drives-imag0345.jpg   painting drives-imag0540.jpg
Rookie is offline
Old 12-15-2011 | 04:28 PM
What primer did you use? mine needs some work its got some peeling going on
sparky24 is offline
Old 12-15-2011 | 04:37 PM
Originally Posted by Rookie
I did mine last winter/spring Epoxy primer and PPG single stage. Fully pitted TRS saltwater drives. Filled, primed and painted. A ton of work filling them and sanding. So far so good.
do you like having white gimbals and drives?
Pokher Ace is offline
Old 12-15-2011 | 05:46 PM
Rookie's Avatar
Originally Posted by catalyst.
What primer did you use? mine needs some work looks like it was painted recently but wasnt prepped right or it wasnt primed because it is peeling.
I edited my first post. I used Transtar Self Etching primer. I only have 1 summer on them, trailer the boat and have only left it in the water 3 days at the most so far.
Rookie is offline
Old 12-15-2011 | 05:54 PM
Rookie's Avatar
LOL, yes I do, if you are referring to keeping them clean. Good wax at the start of the summer. And when I pull it out of the water I wipe the boat down using Meguiars spray wax. When it gets bad I just use a Magic eraser. It more difficult cleaning the transom soot and the hard water stains off of mufflers.
Rookie is offline
