Fastload Trailer parts
Old 12-15-2011 | 01:39 PM
Default Fastload Trailer parts
Anyone know where to get a fitting that goes between the master cyl and the back up solonoid? Fastload can't seem to help me on this. It's a 2005.
Thanks in advance
mcprodesign is offline
Old 12-15-2011 | 02:51 PM
t500hps's Avatar
21 and 42 footers
I owned 5 Fastload trailers.......10 years ago they were great to deal with but not so much around 2007 (I haven't been back since then).
I replaced several "blocking solenoids" on those trailers with "bleeding solenoids". I went to Home Depot and bought short pipe fittings that fit perfect.
t500hps is offline
Old 12-15-2011 | 10:25 PM
I wonder why they even answer the phone
. SO a 2005 is still a good trailer then right? It looks to me like it is a metering jet. ( real small hole) . I can find the fittings but not one w this small of a hole.
Old 12-16-2011 | 06:48 AM
t500hps's Avatar
21 and 42 footers
All that hole doese is pass fluid back to the brakes.....the interior size of the fitting is irrelevant as long as it threads/seals tight into each end.
Since you apparently have the Solenoid off I'd recommend replacing it as I did. Occasionally you need to back up and the solenoid locks the brakes "on" keeping you from backing up. A bleeding solenoid literally bleeds off the excess pressure allowing you to back up everytime. The downside is you have to drill/tap a return line back to the top of the master cylinder.
t500hps is offline
Old 12-16-2011 | 12:26 PM
http://www.easternmarine.com/em_stor...FRNeswodUUUk6A
http://www.championtrailers.com/
Griff is offline
Old 12-16-2011 | 01:01 PM
t500hps's Avatar
21 and 42 footers
here is the exact solenoid I have installed several times (and I got it from eastern)
http://www.easternmarine.com/tie-dow...olenoid-11253a
t500hps is offline
Old 12-17-2011 | 10:53 AM
do you think there is any reason for the tongue to be 8.5 feet longer than the boat?
Old 12-17-2011 | 11:06 AM
Maybe I should move the yoke back like this one is...
