Alpha Mechanical Trim Indicators >
Old 12-19-2011 | 12:08 AM
Default Alpha Mechanical Trim Indicators
Who makes a good Mechanical Trim Indicator for Alpha Drives?
Are they all the same as Bravo or is there a modification required?
Simply put...I have never rigged a performance offshore boat and I'm like a kid in a candy store going through this stuff...it can be a bit over whelming the first time in. I can make it fast...I just want to be able to safely control it!!
sprink58 is offline
Old 12-19-2011 | 06:57 PM
Wow...42 looks at this and not one response...I guess I have stumped every one with this one.
sprink58 is offline
Old 12-19-2011 | 07:15 PM
Sonic30ss's Avatar
I have them on mine....don't know if they fit a Bravo too.
I can take a pic and some measurements for you.
Sonic30ss is offline
Old 12-19-2011 | 07:28 PM
Bravo and Alpha use the same according to REX. You can check it out here. Don't know if you have a single or dual engine but here's a quick quote.
Indicator on dash about $250
Cables about $50 per
Activators that mount to trim cyl. $150 per
cable transom seals about $30 per
About $500 for a single and $700 for dual.
http://rexmar.com/sectiont.htm
pages 84 and 85. Price sheet is at the top in the blue bar on each of those pages.
picklenjim is offline
Old 12-20-2011 | 12:09 PM
Thanks guys...great info.
sprink58 is offline
Old 12-21-2011 | 09:06 AM
Yes..... there are some that are the same. I think Eddie Marine makes one that can be used with Bravos and Alphas. I have twins in a 242 and will be adding them in the future.
jmrapp is offline
Old 12-21-2011 | 09:01 PM
It's sort of confusing because when you start looking for them most are listed as "this for Bravo" and "that for Bravo"...it implies that they don't apply to any drive but Bravo.
sprink58 is offline
