Wellcraft Excaliber
Old 12-20-2011 | 02:55 PM
Default Wellcraft Excaliber
Particularly mid 80's 27ft'r. Solid boat with a bbc? Or an expensive headache? Experiences? Pictures?
machloosy is offline
Old 12-20-2011 | 10:26 PM
nitrousnolan's Avatar
Good solid old wood, but be prepared to run in the 60's on a good day.
nitrousnolan is offline
Old 12-21-2011 | 06:48 AM
Rumor has it that the cockpit are cramped! Thoughts?
Old 12-21-2011 | 08:30 AM
It's no rumor Note there are two people in this picture, no cooler. The 25 is worse, but this is pretty bad
4bus is offline
Old 12-21-2011 | 09:27 AM
Get it surveyed...........
TexomaPowerboater is offline
Old 12-21-2011 | 10:09 AM
got one and gutted it and added bulk heads but when done ran real good if you can find yourself a 27 activator its a modern 27 excalibur and a serious fast rough water boat
JERSEY DEVIL is offline
Old 12-21-2011 | 10:59 AM
How fast/what power?
@texoma, its a sub 5K boat, maybe as low as 4K if she runs decent and passes a visual inspection, I'm not sure a survey is worth time/money in this case.
Old 12-21-2011 | 11:01 AM
4bus, that 99 outlaw is nice but I've got a line on something better for the same $$$ PM me about it
Old 12-21-2011 | 12:34 PM
I'd survey the motor as well - leak down and compression test should be easy on that big single engine boat.
Old 12-21-2011 | 01:04 PM
I had a 1982 rerigged it with a 540 640 hp and did a bravo in it and set the drive height at 19 inches.. Boat ran 85mph all day every day... best I ever went was 87....that hull is a great hull and awesome in the ruff stuff for it's size.Great boat cockpit is a little small because of the 7ft beam but all in all good boat..
excalibur82 is offline
