K Throttles and shifters for twin with hooks >
Old 12-27-2011 | 10:20 AM
Sick Stinger's Avatar
Brotherhood #1
Default K Throttles and shifters for twin with hooks
Set of K series throttles out of a mistress. Move free no binding. Cables were no good or id included those also. I did take off the cable end to controls that will also go with them.
200 to your door
-Mike
Attached Thumbnails K Throttles and shifters for twin with hooks-k.bmp   K Throttles and shifters for twin with hooks-kt.bmp
Sick Stinger is offline
Old 01-04-2012 | 05:03 PM
How much only the 4 hook ?
Perf langlais is offline
Old 01-04-2012 | 05:27 PM
Brotherhood #1
So you just want the hooks for the throttle and shifters? If so id rather not seperate as i would guess who ever buys the controls would need them
Thankyou though
Mike
Old 01-04-2012 | 05:51 PM
Rookie's Avatar
I made some using using 3/16" heim joints with a 10/32" thread. I can get you some pics if you need a visual. The pin can be punched out, grind a little bit on the inner part of the control away for clearance, insert the heim joint and replace pin. I was going to post this in the DIY on a budget form.
I used something like this. You can get them on ebay for $2ea.
Sorry Sick for the Hijack.
http://pitstopusa.com/c-133383-rod-e...-rod-ends.html
Rookie is offline
Old 01-04-2012 | 07:48 PM
That's it !! i already buy the control on ebay and the hook is missing but if you don't want to separate them i will try the idea of rookie. I take a look at the shifter and it's a very good idea !!!
Old 01-16-2012 | 01:15 PM
SS930's Avatar
How much for the lift?
SS930 is offline
Old 01-16-2012 | 01:50 PM
Brotherhood #1
Free to use anytime.
-Mike
