III Speedmaster props
Old 12-27-2011 | 01:01 PM
bigboat28's Avatar
Default III Speedmaster props
I have a #III drive 19 spline with the longer prop shaft. The hubs on the props that are on it are 6"s. Is there a way to get the 4" hub props on it?
bigboat28 is offline
Old 12-27-2011 | 01:05 PM
I think arenson makes adaptors for it. They are not cheap if I remember correctly like 400 each.
excalibur82 is offline
Old 12-27-2011 | 09:54 PM
I've seen some guys run spacers between the prop nut and the back of the prop so they could run the short hub props on a long hub shaft, don't know who makes them but you could probably have a machine shop make something.
J. Hordubay is offline
Old 12-28-2011 | 01:30 PM
Sounds like a lathe project, Dale
It should be pretty simple to build a couple spacers.
RT930turbo is offline
Old 12-28-2011 | 02:55 PM
bigboat28's Avatar
Artie, you volunteering, LOL
Old 12-28-2011 | 02:59 PM
Sure... it would be a piece of cake.
Anybody have dimensions? What material to use? Bronze?
Old 12-28-2011 | 03:01 PM
Shouldn't we be able to just make a spacer to go between the nut and the prop? What does the thrust washer look like? Been a while since I've payed any attention to a SSM...
Old 12-30-2011 | 10:31 AM
My buddy had a setup like that. Short hub prop, made a spacer.
MILD THUNDER is offline
