Mercury 175 xri idles at 2500 RPM
Engine wasn't running when I bought it. Put a new fuel pump on it and it started right up. Now it idles at 2500 Rpm. The throttle body butterfly is shut and still idles high. What should I check next? Is there idle control Senor that could be bad? Any help?
i think even if the tps sensor was dumping in to much fuel it would still need air to get to 2500 rpm not sure if it could idle that high on just extra fuel also have you checked to see what color the plugs are after it just idles for 5 minutes are they white or black?
The throttle arm controls both the intake butterflies AND the timing plate under the flywheel. There are separate adjuster screws for both of them. Even a low butterfly openings, the timing advance alone will make those motors rev when there's no load on them.
Pull the cover. Disconnect the throttle cable from the big arm. Make sure it all moves as it is supposed to from idle position to wide open throttle position. Hold the arm and let somebody fire it up. See if you can move the arm far enough to let the motor idle down to under 800. Vacuum leaks can also contribute, but chances are that you have something out of adjustment from the throttle cable itself to something in the arm and actuators.
There are stop screws for max timing advance, minimum throttle plate opening, etc. Just take a look while you move the arm and watch it all. It will make sense.
You'll notice that the throttle plates only open a tiny amount as you increase the throttle until you get most of the timing in, then the throttle plates start opening.
MC
MC
