GM Truck Owners
Old 06-17-2002 | 09:34 PM
cgarrett's Avatar
Default GM Truck Owners
If you have a newer style General Motors Truck with “Day Time Running Lights” start it up and walk to the front and see if one of the lights is burned out. I can’t believe how many trucks I see on a daily basis with one out. Just want to take a poll of OSO members to see if there are any. Could this be a possible defect?
Start looking, it will drive you crazy!
Cordell
cgarrett is offline
Old 06-17-2002 | 09:43 PM
Hey , I found a great thing for you GM guys ! Call 1-800-GM-truck . It's a pre recorded message .But listen good .For some reason the second you dial the last digit , it starts talking ! You don't want to miss it ! Let me know if it helps !
boot is offline
Old 06-17-2002 | 10:12 PM
mcollinstn's Avatar
Stock bulbs OR aftermarket bulbs, clear OR amber (my preference) ALL burn out within 7 or 8 months. The fixture itself seems to hold too much heat inside it.
The only saving grace is that they are easy to replace and you don't need tools to replace them (pull the pins and yank the whole light out).
mcollinstn is offline
Old 06-17-2002 | 10:17 PM
Just press the dome/overide button 5 times and it will cut them off.
38ZR is offline
Old 06-17-2002 | 10:45 PM
buck183's Avatar
It's actually 4 times.
Buck
#183
buck183 is offline
Old 06-17-2002 | 10:57 PM
Jassman's Avatar
All 4 of my trucks are ok, 99,2000,2001, and 2002 Gms, I must be lucky
Jassman is offline
Old 06-17-2002 | 11:15 PM
Tonto's Avatar
Changed to amber when they new and haven't had a problem since. '00,'01. Guess I got lucky too
Robert
Tonto is offline
Old 06-17-2002 | 11:24 PM
Charter Member #38
on my 96 there was a DRL (daytime running lamps) fuse I just pulled it.
hotbeek is offline
Old 06-18-2002 | 05:14 AM
GM has issued a service bulletin regarding this. They advise replacing both bulbs with a new part number of { I believe} 1999482. {may be 1999982} Short number was like a 3157kx and now is a 4157kx. Not positive of the letters at the end of the short number, pull one of your bulbs to double check. They supposedly burn for a much longer time. Hope this helps.
bucky is offline
Old 06-18-2002 | 07:42 AM
Two of my four trucks have a light out. It is very annoying.
Scuba Steve is offline
