Hawk 525 vs merc 525?
Old 01-08-2012 | 08:32 AM
Default Hawk 525 vs merc 525?
Does anyone know the actual differences between the 2? I have found quite a bit of info on the merc motors but not much on the hawks. A few have said the hawk is just a 420 with a blower. Any truth to this?
Unlimited jd is offline
Old 01-08-2012 | 09:05 AM
Hawk ran higher compression and less timing than the merc. That gave it a different torque curve.
rdoactive is offline
Old 01-08-2012 | 04:04 PM
Keytime's Avatar
Not to hijack, but to expand...
Was quality comparable?
Did Hawk also build a 575?
Keytime is offline
Old 01-08-2012 | 05:32 PM
TomFTM's Avatar
yes, the two we rebuilt in the 90's were basically 420 's with bm 174's .
TomFTM is offline
Old 01-08-2012 | 05:34 PM
174s or 177s? I've read both guess I'll have to look for some numbers on the blowers
Old 01-08-2012 | 05:54 PM
BDiggity's Avatar
My Hawk 525 has a 250 on it. Not sure if previous owner upgraded it.
BDiggity is offline
Old 01-08-2012 | 06:02 PM
Must have been upgraded seems its a pretty common upgrade
Old 01-09-2012 | 01:51 AM
Hawk 525sc's were Merc 420's with B&M 174 blowers.
Merc 525SC's used a lot of the same major parts as the 420's. Same block, heads, and cam. Merc ran lower compression 7.5:1 pistons, more boost and more timing. They used Weiand 177 blowers.
Griff is offline
Old 01-09-2012 | 06:31 AM
I have a set of Hawk 575s??? They have B&M 250s on top. I believe the previous owner upgraded the blowers.
So, were there two models, 525 and 575?
frickstyle is offline
Old 01-09-2012 | 12:09 PM
Merc 525 ran a Weiand 177. Hawk 525 ran a 174 B&M. Ocean Performance was the entire start of that with Bud and Craig.
oceanperf is offline
