Lower unit drain bolts?
Old 01-09-2012 | 01:37 PM
Default Lower unit drain bolts?
I saw some lower unit drain bolts, that replace the standard screws, normally used by Mercury on bravo stye units and on my Sportmaster lowers. Who makes these?? I think they are either a bolt head or hex head design, will they fit on my sportmaster lowers on my 300XS? Thanks
offshoresteve is offline
Old 01-09-2012 | 02:01 PM
Anxiously awaiting a reply to this too.. I stripped out that ridiculously cheap flathead screw. Haven't drilled it out yet because I was hoping for a replacement!
waterboy222 is offline
Old 01-09-2012 | 02:03 PM
I know, have been carrying several extras in my truck
Old 01-09-2012 | 02:28 PM
Whats the best way to get one out that has the head stripped on it?
Old 01-09-2012 | 02:37 PM
I think Imco has them.
Steve
smiklos@sunprint is offline
Old 01-09-2012 | 02:41 PM
JR Marine http://www.jrmarine.com/products/3013.htm
Griff is offline
Old 01-09-2012 | 02:53 PM
Knot 4 Me's Avatar
Take a small, sharp punch and a hammer to get it to turn. Berger's at LOTO showed us this trick this past spring.
Knot 4 Me is offline
Old 01-09-2012 | 04:26 PM
blue thunder's Avatar
Yes. And if it is necessary pull the carrier out and mount in in a vice and do said punch trick.
blue thunder is offline
Old 01-09-2012 | 06:19 PM
Steve
Thanks Steve, ordered a couple of sets of Imco hex head drain and vent plugs. $8.21 ea not bad, no more stripped screws
Old 01-09-2012 | 06:24 PM
waybomb's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
Anybody know if these work on SSMIII and SSMIV?
At least Merc could have used hardened screw heads.
waybomb is offline
