Revolution On A Donzi 26zx >
Old 01-10-2012 | 07:28 AM
Default Revolution On A Donzi 26zx
Anyone Have Any Luck With The Revolution 25p Prop
On A 26zx Donzi With The 502mpi....or Any Other Props That You Have Liked On This Setup.
COOPS is offline
Old 01-10-2012 | 08:56 AM
The zx is a stepped hull correct? The rev 4 is more of a straight v hull. It provides a lot total lift. Stepped boats want stern lift. A bravo4 does that. What are you trying to get from the prop?
GTOFFSHORE is offline
Old 01-10-2012 | 10:15 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
The Revolution 4 will definitely work.
The Bravo 1 props do have better responses to modifications if you need to do so.
Test or try want ever you can. Document the performance data and then we can discuss the findings. I can ask the appropriate questions that will determine the best propeller for you boating style.
Brett
[email protected]
bbladesprops is offline
