Cam Selection
Old 01-11-2012 | 07:21 AM
Default Cam Selection
How many people have used Mechanical Cams? And how big of one has been used?
I am debating between three of them right now in a 556ci big block with Brodix BB4 STS heads. Has anyone used one of these, cams as these are what I have picked out of the Crane book.
Crane Cam Part Numbers.
138681
138641
138791
Kings11 is offline
Old 01-11-2012 | 09:57 AM
How many rpm's to you plan to run? Why nOt just run a hyd?
GTOFFSHORE is offline
Old 01-11-2012 | 10:28 AM
5200-5500 rpm as per the normal.
The cams will make power up to 7200 and I realize that but I'll never run a prop small enough to spin that fast.
Hydraulic rollers just don't make the power of a mechanical cam.
Kings11 is offline
Old 01-11-2012 | 10:49 AM
Your talking like ten hp and you might not see it if you dont turn it. If that is worth all the extra up keep then ok.
By the way I too run a solid with hyd morel lifters so I get it. I turn 6k though.
Old 01-11-2012 | 10:56 AM
As far as cams the last one but I would ask bob Madeira or Eddie young to get it right. None of those looked great.
Old 01-12-2012 | 12:37 AM
Running that RPM, you might as well just go hydraulic. I was running a pretty decent mechanical in my 598ci N/A that was spun 6300-6500 rpm, dropped a valve, changed to a milder hydraulic and still spin 6000rpm regularly, lost a decent amount of power but the overall driveability is worlds better.
Engine made 800hp with a .697/.697 @ valve and 262/272 @.050 solid roller.
Philm is offline
Old 01-16-2012 | 03:14 PM
Call bob madera and see what he has to say. I run a 428 sbc. Solid roller 258/262, .641 lift. 6400-6500 rpm. I spend 45 minutes in the spring time lash the valves and don't have to touch them all season.
mountainmadness is offline
Old 01-16-2012 | 03:51 PM
Rookie's Avatar
I also run solid rollers. Like mountainmadness I spend an hour/engine at the start of the year. @ 0.050 252 / 264, lift 0.632/0.669" on a 108* 6000RPM.
Only reason I run solids is cause I have a lot invested in Isky Red zones and don't want to drop another $1200/engine on new cams and lifters.
Rookie is offline
Old 01-17-2012 | 10:16 AM
I got a stupid good buy on the lifters, so it's solid rollers for me.
Setting the valves once per season is no big deal I'll probably check them and possibly reset them more then that but this is going to be my poker run and long week end weapon.
I still have my Regal for daily and regular outings and with it running mid 80's it's not exactly slow.
I was just curious what everyone is running and how it's going for them, and the last two posts have given me an idea. Similar duration to the cams I ended up ordering but smaller lift at higher rpm.
Kings11 is offline
