How to find out Merc engine model year >
Old 01-11-2012 | 11:16 PM
Default How to find out Merc engine model year
Hello,
does anybody know how to find out the exact model year of a
Mercruiser 502 MAG MPI .
I have the numbers from the Metal plate near by the starter.
Serial # : (O)M021217 and (O) M021215, (maybe a the O in front, but is not written on the plate)
Cast#: 10237300 G200 and 10237300 G180
I found out that they must be 1999 and up.
I need to know from when they are exactly. They must go thru a Certification with the Boat here in Germany.
Thankfull for any help
Hans
Germany
Scarab28Germany is offline
Old 01-11-2012 | 11:57 PM
You might try this.
http://www.mercurymarine.com/contact-us-online-merc/
picklenjim is offline
Old 01-12-2012 | 04:56 PM
Originally Posted by Scarab28Germany
Hello,
Hans
Germany
Both of the serial numbers, 0M021217 & 0M021215 were manufactured on 10/12/2000. The model numbers for both are (4752227N1) MERCRUISER 502 MAG BRAVO MPI ENGINE ONLY, & we're registered new on 07/03/2001.
lakematdude is offline
Old 01-12-2012 | 09:01 PM
Hi,
@ piclenjim, thank´s for this link but does only work with US Citizen
Thank´s
Hans
Old 01-12-2012 | 09:11 PM
Hi,
@ lakematdude,
Very great, good that they are 2000 and newer.
Where do you have it from, i need to have a conformation or a printed list with data´s that the certification office can see by them self, that this info is true, not just written down.
Is it posible to get something like this ?
Thank you very much
Hans
Old 01-12-2012 | 10:22 PM
Hi,
@ lakematdude,
Thank you very much
Hans
You could try asking a mercruiser dealer to see if they would run the serial number's for you, Then maybe they could print or Fax a copy out for you/them, Or you could try calling (you're area?) a mercruiser customer service relations agent at MerCruiser to see if they could help verify by sending or phoning the certification office/You the necessary paperwork. Other than that, I'm not too sure.
http://www.mercurymarine.com/contact-us/
Good luck.
Old 01-12-2012 | 11:19 PM
I will try
thank´s for helping
Hans
Old 01-13-2012 | 02:00 AM
Any Merc dealer can run the serial number and tell you what year they are and when they were put into service.
Griff is offline
