LED Navigation Lights- Powerful Lighting In A Low Profile Design
Livorsi has developed a navigation light with powerful LED lighting within a rugged low-profile housing. These popular LED Navigation Lights are used by performance, work boat and government boats a like.
As you know, LED lights outlast and out shine regular incandescent bulbs. LED lights use up to 90% less energy; these Livorsi nav lights only consume 1/10th of an amp at 14 volts. This means a longer life and less rigging time switching out lights. These lights are to be used on any vessel up to 65 feet and have a visibility of 2 nautical miles.
These lights are designed to be mounted on a vertical surface, to allow the light pattern to be unobstructed from view. These LED Nav Lights flush mount onto the fiberglass surface for a seamless uniform look.
Made of 316 marine grade stainless steel, a highly anti-corrosive metal. This grade of steel has an increased resistance to corrosion, perfect for the marine environment.
o Available for 12 or 24 volt system
o For port or starboard
o Measures 3 1/4" W x 1 3/4" L x 7/8" D
o Made of 316L stainless steel
o Polish finish
o ABYC & USCG certified
o NMMA accepted
o Optional adapter plate is available for White Industries & TH lights
Part Numbers:
Port: LEDNL2R- List price: $69 ea
Starboard: LEDN2G- List price: $69 ea
Optional Adapter Plate: LEDNLAP List price: $26 ea
