H.P. 500 rev limiter >
Old 01-12-2012 | 06:36 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Default H.P. 500 rev limiter
Can anybody tell me where the stock rev limiter is located on a 1999 Merc Racing H.P. 500 ? I have an M.S.D. ignition box with a Jacobs coil . What is the stock rev limit and at what r.p.m. can this engine be safely run ? Thank you kindly .
the deep is offline
Old 01-13-2012 | 02:06 AM
Stock rev limit is 5350rpms. They will run best if propped for 5200-5300. They could actually be run a couple hundred rpms higher without any problem.
Griff is offline
Old 01-13-2012 | 11:26 AM
the deep's Avatar
Fast Singles Club
Thanks Griff . Can you tell me where the rev limiter is located ? I'm still running the stock distributor .
the deep is offline
Old 01-13-2012 | 11:28 AM
There is a plug in on the msd that will tell you the rev limiter limit.. Go to msd and down load a pdf of it and you will see it
fastscarab22 is offline
Old 01-13-2012 | 11:48 AM
Its under the Mercathode on the steel bracket.
Its Part #41 if you have a TB IV ignitionhttp://www.mercruiserparts.com/Show_...CAL+COMPONENTS
Griff is offline
Old 01-13-2012 | 12:24 PM
Not that it matters much, but page 57 of the owners manual in the "Engine Specifications" section says the rev limit is 5400 RPMs.
Still friends Griff?
242LS is offline
Old 01-13-2012 | 12:31 PM
A 99' will be TBV
the rev limiter is built into the ignition module
# 38 in this picture
http://www.mercruiserparts.com/Show_...p?dnbr=853984R 1&ivar=images/CRUISER/853984.R1/5.png&inbr=2450&bnbr=5&bdesc=ELECTRICAL+COMPONENTS +%28SERIAL+%23+0K000001+THRU+0L001772%29
JaayTeee is offline
Old 01-13-2012 | 01:21 PM
the deep's Avatar
Fast Singles Club
So, i guess if i don't have the box with the built in limiter or the soft touch rev control i be runnin without protection Glad i've been quick on the throttle . Thanks for the info guy's . Will check to see what i have when it warms up a little . 17* this morning
the deep is offline
Old 01-13-2012 | 01:34 PM
the deep's Avatar
Fast Singles Club
Oh , so i am ok ? while i was at MSD you guy's posted . Thanks again .
the deep is offline
Old 01-13-2012 | 02:09 PM
If you have removed the stock merc ign box you will not have a rev limiter unless your msd box hase one. griff is right on with the rpm's. what limits them is your valve train.
I also run the stock merc hall efect dist in my hp500's but i run the msd 6al-2 ditigal box's with these you can program your own timing curve and rev limit right off your laptop. they work very nicely.
KWright is offline
