Various fuelling questions! >
Old 01-15-2012 | 10:12 AM
larby's Avatar
Default Various fuelling questions!
Hi all,
I'm just in the process of getting my supercharged 502 sorted to run, but having never built this type of motor before I've got a few questions...
The motor is a fairly stock 502 running a Holley 250 blower on low boost (haven't run it yet but expecting 5lbs tops)
I'm currently running a single Holley 1000cfm carb (80513) and have a small aeromotive regulator attached which seems to be non-adjustable.
Use will be a mixture of leisure, poker runs and race.
So the question is, what fuel pressure whould I be running and what fuel pump would you suggest?
Out of interest, would people say my current carb will suffice, or should I look at changing to dual 750's? I'm not keen to do this due to the expense, but if I have to then I have to!
Cheers, James
larby is offline
