Is this bad?
Old 01-17-2012 | 09:11 PM
Default Is this bad?
Removed from my truck tonight. The photo on the left is exactly what I saw when I pulled the wheel off. A few weeks ago, I had the dealer check the brakes for a grinding noise and got an all-clear!!!
The right brake was perfectly good, plenty of pad left and rotor in good shape.
Replaced both, took about 1.5 hours.
Check those brakes!
Attached Thumbnails Is this bad?-rear-brake-1.jpg   Is this bad?-rear-brake-2.jpg
bustedbrick is offline
Old 01-17-2012 | 09:19 PM
hope you replaced the rotors to...
chewyjr18 is offline
Old 01-17-2012 | 09:27 PM
Nah, I figured it has just been "turned"......
Old 01-17-2012 | 09:33 PM
spazboz's Avatar
LMAO All you gotta do now is switch the pads around so the other side "Turns" itself!
spazboz is offline
Old 01-17-2012 | 10:14 PM
rgrgoog's Avatar
rgrgoog is offline
Old 01-17-2012 | 10:30 PM
Expensive Date's Avatar
Keep an eye on it its odd for one side to wear that much more than the other. Could be a bad brake hose (collapsed) or just corrosion were the caliper slides that was not allowing it to return.
Expensive Date is offline
Ouch, is that on a Ford? Had a very similar issue with an F250 7.3L one day. Even the caliper needed replacing after that.
Jay Gadsby is offline
Old 01-17-2012 | 10:44 PM
Check those brakes!
its only bad if you need to stop,the scarry thing is a dealer said it was good to go,usually they will tell you the brakes are shot,even if they are new.
mike tkach is offline
Old 01-17-2012 | 11:03 PM
Something else caused that wear. Need to find out what or it will just happen again.
Caliper could be sticking, etc.
offshorexcursion is offline
Old 01-18-2012 | 06:19 AM
BONDO10's Avatar
If it's a Ford you need to lube the caliper hardware/slide at least once a year. More often if your backing in the water. I lube all four caliper slides twice a year,or every time I rotate the tires.
BONDO10 is offline
