Ford F350 Diesel 4x4 SRW
Old 01-18-2012 | 04:34 PM
PhantomChaos's Avatar
Default Ford F350 Diesel 4x4 SRW
With there are four axle ratio choices with the SRW and diesel. I have no idea which is better.....or for what reason. Any input? See below.
PhantomChaos is offline
Old 01-18-2012 | 04:47 PM
BDiggity's Avatar
i always like to assume the most expensive option is the best one which i will end up wanting, even if i dont need it.
BDiggity is offline
Old 01-18-2012 | 04:51 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
With the load you will be towing, you definately want the 3.55; and you also want the Locking Rear End for traction on the ramp. (Since I know this won't be a daily driver for you; the fuel mileage is not a concern for said use.)
Since you are looking at 4x4, you will have that in reserve, but there is no advantage to a non-locking axle.
Are you going to send it off and have it changed into an X?
Sydwayz is offline
Old 01-18-2012 | 05:06 PM
An "X"?
Old 01-18-2012 | 05:42 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
An "X"?
eXcursion
Sydwayz is offline
Personally I like the 4.11 gearing for towing at a minimum. Especially towing heavy loads, and a locking/positraction differential is a must. The lower gearing provides for great torque multiplication.
With a 5 and 6 speed transmissions of today, the rear gearing at highway speeds in inconsequential.
Currently I have 4.88 on one vehicle, & with the 35" taller tires on the truck, the final drive ratio is around 4.20-4.30, and 4.56 on another tow vehicle.
45Tripps is offline
Old 01-18-2012 | 05:49 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I tend to agree, but it looks as thought it may not be available.
(Remember, both the front and rear gears need to match in a 4x4, but Ford knows that.)
The 3.55 is more of a mileage gear than a towing gear. But the new Diesels have a lot more power which can and probably does make up for that.
IF you plan to go to bigger wheels and tires, you most certainly will want a 4.11 gear set. Or at least a 3.73. For these you may have to special order...
... or you can change the gears down the road. It's not a major project. Just gear swap changes in both pumpkins, and some computer adjusting of the torque management and transmission shift points.
Sydwayz is offline
Old 01-18-2012 | 07:28 PM
Plus being a SRW, there is more surface area for tire contact for more traction too......
45Tripps is offline
Old 01-19-2012 | 11:06 AM
The one I've found has the 3.55 Electronic Locking Axle. The other choices (which I deleted from the graphic) are only for the gas engine.
Old 01-19-2012 | 11:17 AM
Default 06
Nort, Buy my 06 ! You will just take it to some shop, take the motor out, rip it apart, change the interior, paint it, lift it or lower it, change the tires and rims, never use it and talk about it forever........for $30K less than new.
fossil fuel is offline
