Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
what type of plywood is everyone using >
Old 01-22-2012 | 05:50 PM
Default what type of plywood is everyone using
hi what type of plywood is everyone using for floors and stringers besides marine ply.
panamacitymustan is offline
Old 01-22-2012 | 07:37 PM
okume
mach1magnum is offline
Old 01-30-2012 | 04:53 PM
Default fixx
7 ply birch..
FIXX is offline
Old 01-30-2012 | 09:35 PM
what about seats?
pluguglyinhere is offline
Old 02-04-2012 | 04:40 PM
Marinetech by plumbcreek for floors, w/an a & b face PTP kiln dry. individual 3/4 sheets go for about $75-$85 each.
Flitzr1 is offline
Old 02-05-2012 | 08:21 AM
So any thoughts on seats, I need to replace my sundeck and bench seat plywood.
Old 02-05-2012 | 12:21 PM
You could use Marinetech engineered panels as it will not rot or decay, but if it is in a wet upholstered area it will overtime weep brown water.
The brown is the sugars from the wood releasing due to being constantly wet.
Your other choices are Starboard or Starboard lite.
Whatever you use You need something that will hold staples well.
On Gunnel side cushions, etc. most builders today are using a product similar to Starboard lite but it has a hard foam core base with slick outsides.
You can even bend it over a form using heat strips & heat gun.
I advise using seating foams with anti fungal properties to avoid "The Pinks" in all exterior seating & cushions.
Flitzr1 is offline
Old 02-05-2012 | 01:52 PM
where do you buy this stuff?
flat rate is offline
Old 02-05-2012 | 07:05 PM
Plastic sheet & rod distributors.
In Tampa area you can get it at Farco Plastics.
Flitzr1 is offline
Old 02-09-2012 | 12:41 PM
Anyone try arauco plywood
