Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure >
Old 01-26-2012 | 11:54 AM
2 Trick Rick's Avatar
Racer
Default Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure
It was time... My 2 person F16 Race boat was just not user friendly for weekend bay boating. The driver sat up front and the throttle man in back making it impossible to drive / test this boat alone.
Attached Thumbnails Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-457-2.jpg   Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-457-5.jpg
2 Trick Rick is offline
Old 01-26-2012 | 11:56 AM
Racer
The main goal is to build a comfortable 4 seater with a light weight - yet strong functional canopy.
Something that can be driven with one person instead of two..
Attached Thumbnails Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-cambridge-md-start.jpg   Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-p9040027.jpg   Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-p9040029.jpg
Old 01-26-2012 | 11:59 AM
Racer
Step 1:
START CUTTING..........
We started with removing the canopy - strange feeling attacking your boat with a circular saw..
Attached Thumbnails Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-1.jpg   Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-2.jpg   Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-3.jpg
Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-4.jpg   Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-5.jpg
Old 01-26-2012 | 12:03 PM
Racer
Once everything was stripped away we began to "de-rigg" the cockpit area.
look how thick that sucker is... WOW, Talk about well built (and heavy).
The last picture is the fuel tank(s). They look to be 100 gal. plus tanks and we have one on each side. No need for anything that big on todays race courses.
Attached Thumbnails Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-7.jpg   Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-8.jpg   Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-9.jpg
Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-10.jpg   Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-12.jpg
Old 01-26-2012 | 12:04 PM
Racer
The cock pit was stripped clean and the decking removed back to the cockpit (safety cell) walls.
Attached Thumbnails Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-13.jpg   Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-14.jpg   Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-15.jpg
Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-16.jpg
Old 01-26-2012 | 12:12 PM
Racer
with everything removed we figured out how much room we needed for side by side seating with a throttle in the middle.
Than a quick safety cell cut and she was open.
The first problem I encountered was the fuel tanks. They are built 3 inch's taller than the "floor". I'm looking to attach the seat bases right to the floor to help lower seating almost 4 inch's (check above pic with large aluminum seat base). Lower the better in case of a wreck your more "inside the boat"
Attached Thumbnails Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-17.jpg   Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-18.jpg   Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-20.jpg
Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-22.jpg
Old 01-26-2012 | 12:17 PM
Racer
Next we mocked up cardboard vertical supports that would stiffen up the side area from were we removed the side walls
*I now see this part was completely unnecessary as the boat was well over built and when I glassed in the next part it was ultra stiff
Attached Thumbnails Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-22-.jpg   Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-22-d.jpg   Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-25.jpg
Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-27.jpg
Old 01-26-2012 | 12:19 PM
Racer
The new safety cell walls needed to step out over the fuel tanks give the person(s) in the boat more shoulder and arm room.
Each part was cut and formed into place..
Attached Thumbnails Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-27-b.jpg   Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-27-c.jpg   Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-27-e.jpg
Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-27-f.jpg   Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-27-g.jpg
Old 01-26-2012 | 12:20 PM
With the weight of the new canopy and forces pushing it down in the event of a rollover, the supports may not be overkill!
waterboy222 is offline
Old 01-26-2012 | 12:24 PM
Racer
Everything was removed from the boat and built on the work bench.
Each part was glued and finished nailed into place.
Once everything dried we rounded the sharp edges to help eliminate any possibility of air voids.
Than all the inside corners were gunked with a clean radius. Once again to help eliminate any possibility of air voids.
Than the part was wrapped in 1708 cloth.
Attached Thumbnails Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-28.jpg   Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-29.jpg   Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-31.jpg
Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-34.jpg   Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure-remove-37.jpg
