89 Bravo oil reservoir leaks >
Old 06-19-2002 | 12:45 PM
rws's Avatar
rws
Default 89 Bravo oil reservoir leaks
My Friend has a leak at the bottom where the fitting is on the reservoir for the drive.It is the round style.I am assuming that there is a gasket or oring. Is this a common problem? Is it a simple repair?
Rob
rws is offline
Old 06-19-2002 | 12:59 PM
Mbam's Avatar
Offshoreonly Advertiser
That is usually a cracked bottle -
Mbam is offline
Old 06-20-2002 | 09:50 AM
That vintage is probaly a round bottle. If so, Merc has redesigned the deal and your pal needs to get the new design. It requires a new bottle and transom mounting bracket.
After replacing a couple of cracked round bottles I got the new design and haven't had any problems since.
JohnJan is offline
Old 06-20-2002 | 10:09 AM
imongo's Avatar
Yeah, I got the round ones too. I replaced one and if (when) they go bad I'll upgrade. It is a bad design. Even if they don't crack it is a good chance that they'll leak because the sealing surface of the bottle on the inside is un-even.
Mongo
imongo is offline
GO4BROKE
2
09-15-2008 02:08 PM
jeff32
5
06-07-2006 11:39 PM
BillR
04-25-2006 08:32 AM
Hot Boat
5
01-09-2003 04:18 PM
sheikman
13
08-07-2002 08:41 AM
