Latham Hose Replacement?
I have some fine cracks in two of my steering hoses. I am going to order four new houses and 90* elbows. What I'd like to know is how to bleed pressure out of the system? Anyone know?
In my system I just worked the wheel back and forth for 10-15 minutes with the power steering engine running. Make sure to check the level of the fluid every couple of minutes. The system should work the air out by itself!
Like fireboatpilot said no static pressure. As long as someone isn't cranking the wheel when your undoing the lines you will be fine!
That is what I needed to know thanks guys. I have a weeping (very slow) leak at the base of the ram where the hose is connected. I'm leaning toward sending the rams in for a inspection/rebuild. Talked to the guys at Latham and they were very helpful.
I just want to give Tom at Latham Marine "props" for outstanding customer service. This is the second time I've called him in four years for parts/technical help and each time he was very helpful. He was very informative and even sent me PDF Files of my steering system and P/N's. Thank you Tom.
Chris
Chris
